Ask your questions here and people will help you out.
Thanks
Thanks
PM coming your way.Hey Discount Tire, am I missing something or why am I unable to change the tire size that I wish to get? I am looking to get 19x8 +30 in the front and 19x9.5 +40 in the rear. I would like to run 235/35/19 and 265/35/19 but the site only lets me search 225/35/19 and 255/35/19.
PS will the 19x8 +30 be fairly flush in the front? Is 19x8 +20 too aggressive?
I think you'll be just fine.Just wondering if anyone can help me out here.
I drive a 2011 lexus is350 AWD and
I'm looking to buy a set of used foose speedster rims that come with 225/30zr20 W85. bolt pattern 5x1114.3/100 offset +42
will these fit? will I have any issues with rubbing or anything?
The rear will fit fine. The front should be test fit. Its too close to tell and will likely require some fender modifications.18" JDM Enkei NT03+M - 18x9.5 +40 all 4. Will they fit my 2006 IS350 RWD?
Thanks.
Assuming the spokes will clear the brakes, everything else looks great. You shouldn't need to make any fender modifications if you stick tire sizes and suspension modifications that aren't too extreme.Name:
REPLICA WHEELS-
Model # LX520
Size
19X8.5" Front, 19x9.5 Rear
Bolt Pattern
5x 114.3 mm
Offset
38mm Front & 40 mm Rear
Lip Size:
Color:
Matte Gun Metal
Hub Bore Size:
60.2 mm
Quantity:
4 Wheels
Hi newbie here I was thinking of putting these lfa replica wheels on my 2006 is350 I was just wondering if I'd fit and will I need any fender rolls ects thanks
You'd need to test fit the wheels, they are a little narrow for new IS models. The tires will be too tall.I currently have an 04 RX 330 with the chrome 5 spoke rims. I was wondering if those 18" rims would fit on an IS? I believe the tires are thicker on my RX so I would have to change out the tires also?
Not sure how the staggered tires will work since the rear IS rims are deeper than the rear RX rims.
Standard OEM RX330 -
18x7 +35 5x114.3 - 235/55R18
Thanks!
20's are fairly easy to fit with the correct widths and offsets. You will not need to raise the car if you choose a tire that's the same diameter as your factory tire.I have a 2006 350. Will 20s fit without having to raise the car? Same question for 22s?
Thanks
19x8.5 +35 235/35/19
19x9.5 +20 245/35/19
will these work on an IS350? I know the rear will need to get pulled.. put how much?
