[Solved] Help! Sticking hood latch release
1 reading
4.4K views 14 replies 6 participants last post by  Bempa
#1 · (Edited)
Hey all, I've encountered an issue over the past few weeks where my hood doesn't 'pop' up like it should when you pull the release lever in the cabin. I've searched the forum for this problem, even the Internet but no one seems to be having this same issue, or i'm just not describing it correctly. Anyhow, this forces me to pull up on the hood in a way that I shouldn't have to just to get it open. The last time I had to pull much harder to where you can hear the latch scraping against metal. My fear is that one of these days i'm going to try and change the oil only to fight with the damn hood instead. I'd assume if I had a friend to hold the latch while I open it, I would be fine. But that's annoying and the thing should just work haha
I've tried applying some oil to the seals but it doesn't seem to really help. Are the seals just really old and have been heat-cycled to where they want to adhere to the surface of the hood? Is this even a problem with the seals at all? Any suggestions would be appreciated!
Also, the trunk does the same thing, to which I have found numerous threads about, even one reaching out to the guys over at FIGS to come up with a solution removing the arm bars.
#9 ·
You should start with just get some good penetrating oil on the hood lock mechanism
Well i'll be, grabbed the old PB blaster and it works like a charm now! Probably should have thought of that earlier
Anyhow, any ideas for the trunk? I've heard stories of people with their IS trunk coming all the way open on its own. I just sprayed the rear mechanism, but its the same, just a pop with no movement. Is it possible those thin spring-like bars weaken over time, thus being the issue?
#8 ·
Maybe take a picture of the hood latch on both sides, like the latch and the hood?
Mine also had the problem where it would stick "open" and not latch. Replaced the cable, fixed it. But I don't see how a cable would help your problem, since it's opening and closing it just fine. Maybe leave the hood open, and latch the latch manually and have someone pull it from inside while you watch and see what happens.
#15 ·
Yes i would think that they are pretty weak, otherwise the trunk would fly open. Mine does a pretty slow motion up so it seems to be very well calculated strength.
But i dont know if there is different springs if there is a spoiler on the trunk, the weight from a spoiler could easily upset that spring i believe
Skickat frĂĄn min SM-G950F via Tapatalk
