21 - 40 of 63 Posts
mikefate said:
i believe the new PCS piggyback also can raise the redline/fuel cut to 7200 RPM
It does not. You would need an INJECTOR DRIVEN computer to raise your redline. The Revlimiter is a fuel cut off. You need a computer that directly controls your injectors or you will not be able to remove the rev limit. Tsoprano, PLEASE O PLEASE explain how a revspeed meter will remove the rev limiter rather than making blatantly wrong statements.
The reason the Emangle ultimate can remove the limiter is because of its direct injector control. THis is the reason standalones can do it too and the reason regular piggy backs cannot.
In my opinion, for boost a higher rev limit is DIRELY needed. 6500 or so is a joke.
First have your car dynoed at a dynomometer facility. See what your power band looks like. When you are accelerating you want your engine speed to go only as high as peak horsepower. Any further past peak horsepower rpm and you are losing time. Once you have reached peak horsepower engine speek then shift so it will bring you back down to peak torque engine speed. Keep doing until in highest gear that is relavent at the time. Once you are in highest gear you can go past peak horsepower engine speed to keep the vehicle in that gear. Only time you will continue to gain vehicle speek past peak horsepower engine speed is when you are in top gear. Shifting later than peak horsepower will not do any good. Why try to accelerate when you are losing power.
Just a thought
As a few people have pointed out...the Emanage Ultimate works great for increasing the rev limit. The raised rev limit is seemless and easily tunable in the software.
For N/A, there is no real point though unless you have other breathing mods..i.e. I/H/E. IMO..the header is critical to taking advantage of the higher rpm as it really increases top end VE making the higher rev limit useful. I have had the EMU installed for about 2 months now (thanks fstrnldr!) and it's been working great! Can't wait to get to the drag strip and especially the autox where the extra rev limit can help on those slightly longer strights where you don't have enough room to reach for the next gear but still are kissing the rev limit.
Just a thought
wrong.
you try to get the point where you shift you have the majority of power available. generally this will put peak power in the middle of acceleration of a gear. if you shift AT peak power you drop too far out of power and are not utilizing both sides of the slope.
IS_Dude said:
wrong.
yellowneck = pwned
I currently have or had the stock redline. I remover THE SPEED LIMITER WITH THE RSM. Mike, the PCS ems, will not at this time remove the rev. limiter, or even allow your to raise it.
I will be raising my rev limit to around 7500-7700. It is not safe to go above 7k without some head work, such as valve springs, retainers, clips etc... with that, 7500 is reasonable and highly beneficial to a turbo. If you look at my old dyno sheet, my power curve still wants to go up.. it does not dip at all. with the extra 1000rpm an upshift will almost feel like a damn downshift. see below
what headwork are you getting done?
How do u plan on raising ur rev limiter?
im not telling :taunt:
i am changing my engine management. Im not doing PCS, for many reasons. I will let the cat out as soon as I get the car back.. 5 weeks to go.
I decided it was time to make some real power. 450 daily on pump wasn't enough.
Well then your gonna need to get rid of that GT35r if u wanna go for real power. I figure ur probably gonna go like AEM since lance has the hook up on PnP harnesses now. -B
The thing with that is u said real power. I think it would best if you changed but it is your car. You have to push the gt35r more than you would a bigger turbo and you could make the same power numbers with less boost. -B
understood, but I will guarantee you, it will be spooled much faster than the big boy ;)
I am spooled at 2900rpm for 15 psi...
make the power faster than the other guy, loos less between shifts etc.. I love how fast this thing spools.
The 67 doesn't have bad spool either. -B
I agree.. The 67 spools in the 3's and that bitch FLOWS!! I will put the 67 up against a 35 anyday of the week. It will make MORE power at the same PSI and not to mention its efficiency will eat the 35 alive.
I know the 67 will make more power with less boost. I still think if i did decide to change I would go with the GT42R.
I wholeheartedly agree with you M...
I look forward to running myis300t for some friendly highway runs come the spring/summer when both our cars are completed with their new upgrades...
21 - 40 of 63 Posts
