Maint Req'd light came on, how to reset on '04
1 reading
3.2K views 4 replies 3 participants last post by  1991NSX
#1 ·
My IS300's maintenance required light - I think that has to do only with the oil change - came on. I don't get the oil changed at the dealer so no reset. How do I reset the light so it comes off?
Thanks.
#3 ·
1. Turn the ignition key to the "OFF" position with the odometer (total mileage) reading shown.
2. Turn the ignition key to the "ON" position while holding down the "ODO/TRIP" button.
Hold down the button for at least 5 seconds. The odometer indicates "000000" and the light goes off.
If the system fails to reset, the system will revert to the state before resetting operation. In this case, return to step 1 and try again.
From
http://my.is/forums/f90/hot-turn-off-your-maintenance-required-light-260560/
