Does any one here who runs emange blue retard the timing when tunning w/ the emanage? ive talked to a few people and they just leave the stock igntion timing. was curious to see other peoples input on this subject.
DrDoS said:Does any one here who runs emange blue retard the timing when tunning w/ the emanage? ive talked to a few people and they just leave the stock igntion timing. was curious to see other peoples input on this subject.
dasgalloway said:Typical response for a conservative tune is "Leave vacuum timing alone... and under boost retard 6-8 degrees from the OEM norm of ~22*..." This leaves you around 14-16 degrees of timing @ WOT under boost.
Your milage may vary depending on how your car is built and tuned.
Malekreza11 said:the car wont run 22 degree's of timing under boost. It will retard it well below that because its so sensitive.
When i was piggybacked, at 14 PSI the car was running 8-11 degree's of advance. 11-12 was on a good day. On average it would run 10.
at 7 PSI or so the car run runs roughly 14 degree's on its own under boost. I know it doesnt know what boost is, but it does react to what it hears from the knock sensors and its DAMN sensitive, but it does a good job of protecting the motor.
dasgalloway said:Like I said, run 14-16 degrees... better to have it preset to that than let the stock ECU do it once it sees a problem.
I hope you're not going to argue it's better to let it knock and have the stock ECU correct than never knock at all.
Malekreza11 said:the stock ECU pulls timing way before it see's harmful knock. Its VERY sensitive, the slightest amount of noise to the knock sensors will cause the car to pull a crap load of timing..
dasgalloway said:If you were tuning a standalone with a J&S Knock controller... would you set the standalone way high and let the knock controller retard to what it thinks is a safe level...?
Or would you tune it correctly? :lol:
Malekreza11 said:you are missing the point here and are starting to go a bit off tangent.
The stock knock sensors are SENSITIVE. Which means, before any harm can be done, the ECU has already pulled a decent amount of timing, and usually will pull alot more than necessary and wont add it back for quite some time to make sure its still SAFE.
Many people here run stock ignition control on piggy back. I did up to 17.5 PSI on 91 octane. Problems? NO. Brandon runs 16 daily, problems, NO.
Im not gonna get into a pissing match with ya bro. Seriously. Stock ignition timing is safe. You can rely on it, thats all i will say.
An ignition harness for the eman is ideal to ADD timing, and yes the IS300 ECU will still pull from what the eman does cuz the timing is piggybacked.
