41 - 42 of 42 Posts
That member has not been on the forum sense 2017. Old dead thread. You should continue on the thread you started. MPX translates.
what does the stock ECU require in order to output a tach signal?
not sure if this is accurate but every forum I’ve seen says to feed the tach signal directly to the cluster,but no ones says they’re sure about this
so which is it?
so which is it?
Never had to get a tach signal for anything I was doing. I know the tach signal is 3 coils combined at the ignitor. There is a signal there.
41 - 42 of 42 Posts
