Hello- I have searched through the site and cannot find instuctions for removing the center console. I have a 2002 is300. I see 2 screws in front, 2 on the sides- what else am I missing? Thanks
its a bia. there are the two in the front, two in back in the little console, then you need to remove the shifter ring. should be screws there and then remove the e brake handle. i think that may be all. someone correct me if im wrong.
Haven't done it for awhile, but it's pretty simple. In addition to the mentions above, just pry up the shifter ring with a flathead screwdriver. once you get that up, it should be self explanatory. The e brake handle cover just pulls up as well. use the flat head at the bottom of the e brake handle cover right next to the passenger seat and pry it up.
