Where's the oil drain plug?
2.7K views 8 replies 8 participants last post by  Eminence
#1 ·
I'm a newbie and I want to my own oil change this time. I finally loosened the oil filter (that was no fun). And now it's time to drain the oil. From under the car I can see a couple of bolts that could be it. Could I get some guildance? Thanks
#2 ·
Find oil pan.
Unscrew the bolt on the oil pan.
#6 ·
look under the car. On the bottom near the sway bar is a black oil pan.
There is only 1 plug on it. It faces the passenger side.
#8 ·
as soon as you get under your car the oil pan is practically in the middle and the plug is on the passanger side 14mm
#9 ·
SephirothIS said:
drive around until your car is warm. Feel around for a flat spot on the bottom of the car that is warm. the plug on there is your drain plug
Nice way to get some real nice burn, I hope you're not the type of guy who takes his own advice. Btw driving the car around doesn't warm the engine it makes it hot.
