141 - 160 of 165 Posts
You guys can find body and panel parts by going to ToyoDIY.com.
Be sure to use the Hola browser extension for Chrome and set your VPN country to Russia. Without it, you won't be able to see the diagrams.
Click "Doesn't work" in Hola until the pictures show up :)
Reactions: Poke_IS300
Hi Folks, I realize this is an old thread but that said I'm trying to locate a good download for the 2002 IS300 shop manuals. I did find a live link for the 2005 but nothing for the 2002. Any input would be appreciated.
Thanks!
Thanks!
There is not really any difference in the manuals. The wiring is different in the 2001 vs the 2002 to 2005.
Thanks man, whats of concern right now is the timing belt & which kit to use along with understanding why theres such a procedure other then take old off put new on WITHOUT moving cam/crank position.....
Because it is an interference engine. If it is off even a bit. It will bend valves. Make sure you replace the cam and crank seals. Depending on mileage you should rebuild the VVTi gear also.
Not Noob to web forums, am Noob to Lexus stuff. I just bought a 2002 IS300 Sportcross (today!) and hit AMZ to buy a Chilton's manual, and searching AMZ for it is just a mess. I've tried a few links in this thread and they are either dead links or require me to install some browser extension to view (which I will never do). Can anybody point me in the right direction - free way to view, pdf download without installing crapware, way to buy a Chilton's or equivalent, etc?
Noobs everywhere appreciate the help!
Signed, Noob, who just bought a running 2002 IS Sportcross for $2000.
This is where I found the 2005 manual, it is supposed to be the same except for some wiring schematics if I recall. It's a good site either way!:
