BBS RX 17x8, will it fit
1.9K views 7 replies 6 participants last post by  N V ME
#1 ·
Alright so I went out and bought a set of BBS RX and they're 17x8. Now I'm worried, without knowing the offset, I bought the wheel because I couldn't find it on the wheel and it looked pretty high. Now I learn that the offset is termed ET. And on the wheel it says ET10 so does that mean it has an offset of 10?? That is toooo low for me, will it fit my car with no mods or will it rub the fenders?
On second thought, does the ET10 mean that the center is 10mm away from the outer rim of the wheels? so the offset if like 40 or so? Help.
#3 ·
ET 10 = +10 Offset
Is it +10 all around? You won't get it to work without some fender work.
I was hesitant against getting fender work done, but it actually isn't a big deal.
#4 ·
You bought wheels without knowing the offset??
#5 ·
Okay so this is really bad too, cause I didn't even try them on. Just saw that it was 5 lugs and the guy told me it was 114. But man 10 offset really? They don't look nothing like 10 offset??? Man this is bad, I'll try them out and see. Report later
#7 ·
Take a pic of the inside of the barrel and post on here....I wanna see the specs.
#8 ·
Dood, you don't even know if they are 5 x 114.3???
Try them on and take pics.
