Founder
We've got race pipes on the shelves right with your name on it. Order today, ships today!
Is it technically illegal to have these installed? I've read about all the gains and want one, but what does it remove, catalyic converters? Also will I pass vehicle tests in the future?
Thanks
Founder
If your state has a visual inspection you will most likely NOT pass. The XERD pipe* removes the last catalytic converter in the exhaust (The first TWO are in the header).
However, the pipe is easily removed and replaced with the stock in under twenty minutes.
*Race pipes are for off-road use only.
