21 - 40 of 51 Posts
Discussion Starter #22
Just thought I would add in this picture showing exactly how are ballasts are designed specifically for aftermarket HID applications:
This epoxy seals the ballast and helps protect against harsh weather conditions.
Steve
I just bought a 2008 IS350 but didn't go with the HID option, but now i want HID lights... What do i need to buy and is it easy to install myself?
Discussion Starter #26
Hi,
The IS uses an h11 bulb for the low beams meaning that you would need to order an h11 HID conversion kit for the low beams. Our H11 HID conversion kits are available in 4300k, 5000k, 6500k, and 8000k (and 3000k). When it comes to colour temperature, the higher you go in terms of colour temperature the more colour you obtain however the less actual useable light output you emit. The h11 Xtreme 4300k HID conversion kit will getyou the most OEM look and feel. You can find our 4300k HID conversion kits listed here:
Xtreme Digital HID 4300k Xenon HID Conversion Kits Upgrade your lights to 4300k Xenon HID light by using one of our 4300k Xenon HID Conversion kits. Our 4300k HID Xenon kits are available in H1, H3, H4, H7, H11, 9004, 9005, 9006, and 9007.
You would just need to select the "H11" option.
Steve
im lookin to convert both my low beams and fogs to HID in my is250. what all needs to be changed and how does it hook in with the existing harness? could you help me out? thanks
Discussion Starter #34
Hi Guys,
I have gotten some questions from people asking if this promo is still on so just adding in that this promo is currently on until the end of this month.
Steve
21 - 40 of 51 Posts
