1 - 20 of 21 Posts
Ok, this morning when i woke up..i decided to clean out the garage..so i backed my car out of the garage and parked it right next to the garage...took a whole 10 seconds to do...and when i did back out of the garage..the car was totally normal...so when i was done cleaning the garage ..about 20 minutes..i started the car back up to put it back in the garage..but this time when i did start the car...the "CHECK ENGINE" light was on and the "TRAC OFF" light was flashing every 3 seconds...WTF? when i started the car 20 minutes before it was totally normal..moved the car 10 feet and now it has 2 lights on?
'02 GGP IS300
44k
i moved my car 10 feet and nothing was wrong and then 20 minutes later i turn it on ..and the check engine light is on and the trac off button keeps flashing
Try diconnecting the battery for 20 min, then reconnecting it. The ECU may have had a brain fart.
same thing happened to me... try resetting the ecu first before jumping to conclusions if it doesnt go away then take it to your dealer.
probably a misfire too. Just reset your ECU, if it comes back, take it to the stealer
1 - 20 of 21 Posts
