1 - 20 of 21 Posts
anyone have this problem? the tank is full i kept pumping the handle and nothing. checked the lines under the hood and nothing inside them. any ideas?
no it was about 60 when i first tried. i dont hear anything.l i didnt know there was a pump i could hear?
There should be a pumping noise when the washer fluid button is pushed. Kind of like a "whirrrrrrrrrrrrrrrrrrrrrrrrrr".
Manufacturer of Pipes
Do a visual inspection of the actual nozzles, make sure there is no wax build up or anything else that can block the jets. Hard water will also cause a whitesh/greenish build up too.
Joe Z :chill:
yeah i did i mean i even unplugged the hoses from the jets on the hood and they were dry so nothing has even made it to the hoses
is it when you press the little button on the end of the stick to do a one squirt? if so, just refill your fluid, you will be fine.
if not then it could be the pump, but this happens to me once and awhile. I just refill and its perfect....
David
the fluid is toped off. i pull the right lever next to the stearing wheel where you control the wipers forword. theres a button to push?
if you pull the lever it just makes the wipers go once. at the end of the stalk there is a wiper button. lean to your right about a foot and you will have an unobstructed view of the windshield wiper stalk
Do you push the button or pull on the lever?
That may be your problem.
Discussion Starter · #14 ·
i pull the lever like i have done in everyother car, i didnt know or even think about a button. this could be the prob i try today. thanks
Not Officially Back
Pulling the lever just wipes once... to squirt you have to push the button.
Or thats what she said. :eek: :lol:
Discussion Starter · #16 ·
yeah im idiot didnt even see that obvious button, cause i wasnt looking for one.
CharlieD06 said:
Did you like never have to use the squirters before?
Is this like your first car?
Discussion Starter · #20 ·
no i never used the squiters on this car before had no need to car was always clean and its only 4 months old. no cars i have used had button squiters u always pulle the lever back.
1 - 20 of 21 Posts
