1 - 12 of 12 Posts
NHRA requires SFI helmets, what do these events require?
David
Helmets
This event requires a helmet with a Snell rating of 95 or higher. I got mine on eBay used (but looks brand new). A google search of "Bell helmets" brought up lots of vendors, but I have no experience ordering from any of them. Bell has a range of auto helmets starting at about $200.
ISzBest said:
Hey i Saw Stan up there, glad you signed up, i'm the younger of the Daves (there's two). Where did you buy your helmet from and how much? Thanks
I guess that makes me the wiser of the Daves. As long as you don't call me the slower of the Daves to my face. :lol:
Glad to see other IS300's out there. See you in a couple of weeks.
Thanks Dave for letting ride with you for a few laps, very educational!
I just installed some sways this last weekend and hope to get a PLP intake on before the next event. My street tires (Potenza SO3's) got chewed up quite a bit at the last event so I see a set of track rims and tires in my future.
See you there, and hopefully it will cool down a bit by then!
Stan
As I mentioned above, I installed Eibach sways this weekend. Although the instructions didn't mention it, should I have the alignment checked with the new sways, and if so, should I run them a few hundred miles first or have the alignment done right away? Thanks in advance.
Alignment is not necessary when installing sway bars. Reason is that suspension geometry did not change.
Dave said:
Was another good day at the track..
It was nice meeting the other Lexus drivers. See you next time.
Yeah that was a blast, thanks for the ride Dave. Now its time to start saving for some racing tires/rims. 8)
You shouldn't need an alignment as a result of the sways, but if you're still running stock specs, you should take this opportunity have it done. Max our your negative camber (on a stock ride height car) keeping everything else w/ in factory specs. This should get you a little more grip.
Guys, don't jump up to race tires too soon. Learn the limits on the stockies first. Race tires are much less forgiving and not as good a learing tool.
see you next time
1 - 12 of 12 Posts
