1 - 8 of 8 Posts
They will not fit the front PERIOD. Sorry. They Will fit the rear though with a shaved fender. You also shouldnt run anything more than a 245 tire with that offset and width in the rear. You will be pushing your luck.
The answer is a DEF no on the front.
As for if they will clear the front brake calipers, it depends on the spoke design of the wheels. It shouldnt matter anyway, with a 35 offset and 8.5 inch width, they wont fit the front anyway unless you get flares and cut the existing fender underneath completely to fit.
don't do it!
with an 8.5 inch rim i would reccomend a 48 offset. But you most likely will run into fitment issues with your brakes.
After owning the manaray's which were 8.5 with a 45 offset, i would never do that again.
In my opinion you should run an 8 inch wide wheel in the front with a 235 tire and a 8.5 or 9 inch rim in the rear with a 255 to 265 tire.
What's wrong with the Manarays? I always thought it was a good fit...
1 - 8 of 8 Posts
