If I put 18" or 19" on my is and then drop it a 1" will the clearence on the bottom of the car remain about the same as stock.... I am trying to lower my car and put bigger rims without it getting any lower ride hit than stock.. thanxs..
If you lower the car an inch and then put on either 18s or 19s while keeping the overall wheel diameter the same as stock then the car will still be an inch lower than stock. The only way to work around this is put on tires with a larger aspect ratio but then your speedometer will literally be off.
My car got higher (Ground Clearance) after rims. Before i used to always scrape my Hiper, after rims I have three people in my back seat and nothing
