If you wish to tackle the install yourself and not have a professional do it, here is what is needed for the front door mid build outs. To properly get the mounting as it was factory (Flush against the door panel), you need to use a 3/4" piece and a 3/8" piece coupled together to give you the same build-up that the factory speaker gave. To help seal the speaker build out to the door, you can use 3M double sided tape or foam weather stripping which are both available at your local hardware store.
