Will acetone melt plastic engine covers if they are painted with high tempature engine paint?
I saw it has been discussed....but i could not find a final answer on if it does or not. I want to paint mine, but if i dont like it i want the freedom to be able to take it right off.
Has anyone done this ir has anyone heard or outcomes from it??
Rather than removing the paint with acetone why not just repaint them black if you decide to go back to stock?
That's the best idea. If I get tired of mine, i"ll just paint them black or go to another color.
And yes, acetone will try to dissolve many plastics. I would never try to remove paint from plastic with any sort of solvent.
alright thanks so much guys....if I just use my rep caliper paint or something will it look shiny or dull....also i have a clear coat i can put on....will it look good or stupid?? IYO
Make sure you clean the cover well with a good degreasing soap and water before you try to paint it. Also you may need to use an adhesion promoter or a plastic primer to make sure you get a good bond.
