1 - 8 of 8 Posts
With no offset info, no one can answer this question. Think before you post
Most likely not, unless you get some wacked out offset
the offset of the wheel, not the size of the tire. what wheels are they, somebody will know the offset of them if you post a link to them. also, you can probably go with 225/35 without rubbing with the right offset. least your tires wouldnt look real skinny
I have 19x8 +45 ALT x - philes wheels with 235/35 1.5"drop with Tein HA coilover
No rub except for full lock while backing out of a parking space. in that case it rubs the plastic liner in the wheel well very slightly.
No rub at normal driving condidition.
Going 19x8.5 and 19x9.5 soon so that will be a whole different story.
I have 215s on my 19s.....here's my advice, dont get them. The look like crap because they aren't wide enough to go over the lip of the rim. Plus, they offer absolutely no protection to the rim. go with at least 225s, and if you can definately go wider.
Discussion Starter #8
ok im gonna get the wider tire when i do, the rims are ACE Manta. Flatlinegraphix has them on his red is.
1 - 8 of 8 Posts
