1 - 20 of 35 Posts
Mr. Negative
just so everyone understands since it seems a little confusing unless you know.
The UEGO1000 is the EFI Systems Wideband which can be ordered from www.efisystems.com mentioned above. It's also sold by PFS and is sometimes refered as the PFS wideband.
Guru of Supercharged ISs
going4boost said:
I have the techedge from Australia seems to be the least expensive unit when coupled with a Palm
How much?
what does it come with?
where to order?
thanks
i still have a nice little palm....
The PFS does not sell the standard EFI wideband. If you had both widebands on the same car they would not give the same mixture readings. EFI does however build a wideband for PFS with a completely different calibrations :wink:
Mr. Negative
Not sure I completely understand. I know he prides himself on a very accurate and simple wideband that he was eventually going to link into the EMS. Why would one have different readings than the other? Different voltage output range for the tec3 or something along those lines? Any info would be cool.
motorheaddown said:
http://www.plxdevices.com/M-Series_productinfo.htm
Great W/Bs, supports the NGK sensor, is endorsed by HPF, and is reasonably priced. I've used the M-200 (without compensation) for months, and it works great.
-scott
This will work fine on the IS?
All you do is replace the factory o2 sensor w/ this one? Thats what it seems.
The rear one, I take it?
-scott
Well, I would imagine sensor 1, pre-cat, because although I did not read motorhead's link, I know that widebands should be installed before any cats to ensure proper operation.
-Chris
1 - 20 of 35 Posts
