planning to buy Kicker 07TCVT124 12" 800W sub.
Peak Power 800W
RMS Power 400W
Impedance 4 Ohm
which kicker amp zx series should I get??
is the zx300.1 (150rms 300 peak) enough or I need the zx400.1 (200rms on 4 ohm 400rms on 2 ohm..) or better?
I'd ask that you reconsider on that sub choice. Those really aren't that great and they are 4ohm which means you'll spend a lot of money on an amp to get ANY power to it.
if i get the same sub with Impedance 2 Ohm
i will get more power from the amp right?
slim sub is my only option, need the truck space..
Yes, 2ohm Cvt and a kicker 400.1 combinations will yield the best results in your case, ive had that sub before its a great slim option, but output is modest and it doesn't handle the lowest notes that well. but overall its okay
Discussion Starter · #6 · (Edited)
i just bought this setup...kicker tcvt10" + kicker zx400.1
a little confuse with the amp wire kit, on the amp manual, it says need 4 gauge ground...(the amp will use 40 Ampere)
now, do i need a 4 gauge amp wire kit, or an 8 gauge wire kit will be good?? i bought the kit tho, pk4, just curious..since it only use 40 ampere...
