I know this is a dumb question but I just wondering where should I raise the car from front and behind. I'm not refering to the 4 jack points on the sides for changing the spare tires. For most of the front wheel drive cars, they have a jack point at center of front and back which you can use a big jack to raise the half of the car up, then put jack stands at the 4 jack points on the sides. Anyone has an idea?
The Rear Pumpkin, The Front Cross Member Where The Lower Chassis Brace Bolts To.
on the side of the car there is a seam weld, always use that when I jack mine and on other cars
also you can use the front tow kitch under the bumper cover. sits in my jack nicely
Thanks everyone for the help.
Btw, is the pumpkin you referred to the differential?
