Podiatrist
PM me or get me on AIM.
3 point or 4 point. Are they quick release from the rear section so that passengers can unbuckle them?
Podiatrist
remove the seat bottoms.
You'll find 4 seat belt anchors. Problem with this is the angle that you bolt the anchors in. You might have to bend the metal brackets to get it to fit right.
I didn't like the 4 point because the angle that it makes with the front seat-back and the rear seat bottoms is gonna be almost 45 degrees. That really isn't recommended. You should try and keep that as parallel to the ground as possible...or even a little higher.
There are only 3 shoulder seat belt anchor points to mount to. I guess if you wanted to, you could attach the 2 corners, and share the one that is the center rear seat shoulder anchor.
