1 - 8 of 8 Posts
Carpets are damp behind the drivers seat and I can hear water "sloshing" around in the dash. Based on other internet searches I suspect my evaporator drain is blocked but I can't find the drain hose. Any ideas (picture would be awesome).
Searched for pics and didn't find, but the drain line is in the engine compartment, in back against the firewall, on the passenger side. If points straight down.
I don't see how it could be the cause of a wet carpet behind drivers seat. The sloshing/gurgling you hear in the dash is more likely engine coolant circulating through your heater core. Do a good burping of the cooling system to get out any air.
1 - 8 of 8 Posts
