1 - 8 of 8 Posts
i'm alil dissapointed because i was hoping for high 14's but all i could get was low 15's
my first run at the track was my best run of the day.
r/t. .579
60'. 2.369
330. 6.412
1/8. 9.770
MPH. 73.33
1000.. 12.631
1/4.. 15.051
MPH.. 93.03
the trap speed that i've been hitting all day should well be in the mid to high 14's. i guess that track i went to is pretty shitty.
what do you guys think?
are you losing traction off the line? those aren't very good 60' times.
i think the track i went to really sucks cause alot of people there including some of my friends could get traction at all.
also i just noticed you live in minnesota which is at a higher elevation, you won't run as fast as you would at sea level.
r/t. .579
60'. 2.369
330. 6.412
1/8. 9.770
MPH. 73.33
1000.. 12.631
1/4.. 15.051
MPH.. 93.03
The main thing hurting your 60 foot time is those 19's you got. I think with the stock 17's you might been even able to get 2.1x's and therefore put you into the 14.80's. (Trap speed won't change) Also, you could technically say your 14's if you have a track with elevation with a correction factor. I think a 15.05 at 93 is very respectable with a car with 212rwhp at 3400 lbs. (race weight)
Discussion Starter #8
i was running on my stock chrome 17's.
1 - 8 of 8 Posts
