I have the H&R springs on my car with a 2" drop and want to get new rims. 19's are what I want but think they would not fit. Does anyone have the same spring setup with rims? I'm thinking bout putting stock springs back on and putting 19's and ground effects..that wouldn'y b to much of a change in height since the ground effects will make it look lower-right?
Threadlocker
plenty of people have wheels and h&r's. you just need to make sure you get a high enough offset so the outer edge of the tire doesn't rub against the fender...
I'm on H&R's and Konis. I dont rub at all unless im cornering hard. Day to day driving i'm fine. 45+ offset.
