· Registered
As far as I understand, the IS uses an engine similar to the GS300; why is it then that the GS gets marginally better gas mileage even though it weighs 300 lbs more and has 5 more hp? I is confused...
· Registered
nope, GS300 doesn't get better mileage than IS. I can tell you this because my dad has the GS and I have the IS, and I am getting at least 1 mpg better than him, and he is the more conservative driver of two.
· Registered
Alot of people have noticed that and wondered.
The factory stickers show that the GS300 has slightly better "EPA" highway mileage.
I have heard the following stories from Lexus people:
1> The IS300 has shorter gearing (different differential ratio) which accounts for the reduced mileage (higher engine RPMs in the same gear at the same speed).
2> EPA testing is a really funny business and any number of small differences between the cars could impact the results. "Real world" mileage may be different than the EPA numbers.
· Registered
Long ago, I posted a link to a URL that describes how the EPA does mileage testing...and get this, they don't actually measure the volume of gasoline consumed. Instead, they measure the emissions from the exhaust, and I guess there's some formula to figure out the mileage. How wacked out is that?!
Here's the URL (you'll need a .pdf viewer like Acrobat): http://www.epa.gov/oms/cert/factshts/gasmel.pdf
