1 - 13 of 13 Posts
What have some of you been using to clean the NAV screen. It seems kinda hard sometimes not to leave streaks.
Cool, thanks guys 8)
Endust for electronics is good, i use my oakly bag for quick cleaning, and sometimes i use the wipes for my LCD screen at home.
IF you ever get stuck nav buttons, there is some stuff out there that is a foam thats safe for electronics (just make sure the nav and car are off). You spray it on and let it sit for a few seconds, then wipe off. It will make the buttons work like new again.
Its funny you mentioned the stuck nav buttons, I spilled a little bit of soda a while back and one of the buttons is still a little sticky. I'm guessing any large electronics store will carry the foam??
Yup, i got it at Fry's Electronics. I will post the name when i get home (its a blue can with a white top). Works like a charm.
I wish the nav buttons were in a different spot, they are too proned to spills where they are. :cry:
isn't that the stuff you use to clean computer keyboards and such? It's like pressurized air I believe.
No. It is a kit that came with a spray & a brush to wipe the screen clean, that is used to clean flat screen monitors...
There is a product sold at Apple Stores called iKlear. It is made to clean iPod, iBooks, laptops screens and flat panel monitors. It is by far the best lcd cleaner I have ever used. Far better than 3M.
TahoeSSDVD.......You Rock!
The last two times I took my IS300 to the dealer for scheduled Maintenance I told them to check out my Nav buttons because they were sticky. When I went to get my car I asked the service writer if the Nav was checked out and she said yes. I got in my car and it was the same and to make matters worse I pushed the info button and it got stuck. I did call her back and she then went on to explain how the tech could not do anything about the problem. I couldn't believe they were unwilling to fix it and certainly was miffed she conveniently neglected to mention anything until I called her out on her deception.
I stumbled across this site as I was looking for possible solutions to my dilemma and found your post. I went straight to Office Depot and bought a spray and when I got home I sprayed the buttons and went inside to eat dinner. After dinner I went out and sure enough the buttons are working smoother than they have in a long time.
I am so grateful for the useful information.
It is exciting to find so many helpful posts.
Paul
Lenspen makes a lenspen call notebook pro. It is a carbon based degreaser. It works great on LCD monitors as well as touchscreen.
Reactions: Platinum288
1 - 13 of 13 Posts
