1 - 2 of 2 Posts
The main side tire that gets hit with power the most essentially is the right rear. LSD or non is the same. The LSD will start to put power to the other side slightly after power and slippage happens. But it is almost none. Unless your gears or clutches in the diff are worn or set loose.
1 - 2 of 2 Posts
