1 - 11 of 11 Posts
I live in a city where they check OBDII codes for emissions testing and will soon be the proud owner of an IS300. What can I do without tripping the check engine light? Any chance that replacing the Y-pipe will be OK? I already plan on exhaust and intake.
Has anybody done an Altezza Beams 3sg swap?
Thanks Guys.
Replacing or removing your rear cat will not trip a check engine light, because bank1 and bank2 sensor 2 (rear most o2 sensors) are placed BEFORE the rear cat. Thus, they will register the exact same readings even after removal of the cat.
A header WILL throw a CEL, as it removes the primary cats, and now sensor 2 (rear o2 sensor) will be sniffing untreated air, resulting in an "emissions below threshold (p0300)" check engine light.
Hope this clears up some of the confusion and misinformation.
-Chris
1 - 11 of 11 Posts
