1 - 16 of 16 Posts
· Registered
On my way to work today, I was cruising down the highway then exited. First stop light I hit after the highway exit I hit a red light and was getting ready to turn. As soon as my IS300 came to a stop, the engine died! Several warning lights came on including the Check engine light. I restarted the car and everything was fine. No warning lights at all. I continured driving to work and the car was just fine...no problem. When I got to work I popped the hood and checked the oil level and that was fine too.
Was this some kind of fluke or something? Any ideas?
I will drive it some more on my way home tonight to see if it happens again.
[This message has been edited by wazzup (edited February 16, 2001).]
· Registered
Call the dealer and explain tot them what happened adn demand a free check up.
Most likely, they will say they found nothing but I would do it anyway to have documentation in case any future problems may arise.
its always a good idea to cover all your bases and be safe.
Straight up in my 01'BlueMicaBlack
All Flava
· Registered
GREAT call man, it's always best to be cautious with something like that... could be a 1 time thing, but if not, it's better not to get screwed.
· Registered
Wazzup, I had a similar experience as you. I was cruising on Santa Monica Blvd. when all of a sudden the lights on my dashboard started flashing. First was the traction conrtol lights, then the engine, then the blinkers. Next the radio started to go on and off. A few minutes later, the engine went dead. Luckily, I pulled over before the engine died. Can you imagine my embassassment to have a new car die on Santa Monica Blvd?! Anyways, I called the Lexus road service and had it towed to a nearby dealer. The whole problem was because of a faulty alternator. The battery was drained which caused the electrical system to go haywired. I suggest you look at your voltmeter to make sure the charge is between 9 and 15 volts. If it's below 9, your car is not getting power from the alternator and the battery will drain soon.
· Premium Member
I experienced the same problem a while ago in my 98 ES300. Turned out to be the alternator like onefortheroad said. Battery wasn't being re-charged properly or something. Got the alternator fixed and everything was cool.
Reefa
· Registered
I had this happen to my Eclipse once before. It wasn't to the point where engine die completely, but you could here the engine went totally silent for a fraction of a second and every instrument in the car went dead during that time. I never really quite sure what happened as it only happen once. My only guess at the time is that there maybe some surge that went through the car, since the ground was wet and I was in the parking lot outside of Fry's where anything can happen.
· Registered
Seems like in your case, the warning lights don't really mean a thing.......They came on AFTER your engine died, right???? Whenever you turn on the ignition, those same warning lights come on anyway.......
But you should have it checked out.......Have you used any fuel system cleaner lately?????
Try Castrol Syntec fuel system cleaner. It works amazingly well....Clogged injectors may cause rough idles and could lead to engine stalls......
My 2 cents.....
[This message has been edited by dude (edited February 16, 2001).]
· Registered
Discussion Starter · #16 ·
Well I drove my IS all weekend and it never died again. Oil and Battery levels check out.
I'm approaching my 10,000 mile mark and will mention this to the dealer when I bring it in for it's next service appointment.
1 - 16 of 16 Posts
