glue it, epoxy it, what ever you think is necessary, as long as it works, and I'd probably try and throw in some kind of bracing like a thin strip of AL or Carbon if you have any laying around, glue it all together, use a vise, or even vise grips to help set it, and you should be golden.
It will still b okay even with 2 tabs are broken. I would not transfer the oem tab to the altezza coz it wont make any sense.
Even u glue it on it will still break in the future!
What I did with my z-edition grille was put a small bracket to make it stable but I will not break the other tab from the other grille.
thats not going to hold. the clip will break again sooner or later.
but you dont really need the tabs.
