I know a boost guage is always one, but what are the other two usually and why?
stick
stick
It's not boost pressure, but I'm sure you can swap out the MPG gauge with the Oil pressure gauge in the Altezza. But making it work is another problem. The oil pressure sensor on the IS just provides a signal for the warning light, so it won't do any good hooking it up to the gauge. Maybe there's a oil pressure sender (gauge type) from another Toyota car that can fit on the 2jz?crontab said:Speaking of gauges, has anyone ever hacked the guages on the stock display? Like the mpg one or battery V one to show something else like boost pressure?
stickninja said:It's not boost pressure, but I'm sure you can swap out the MPG gauge with the Oil pressure gauge in the Altezza. But making it work is another problem. The oil pressure sensor on the IS just provides a signal for the warning light, so it won't do any good hooking it up to the gauge. Maybe there's a oil pressure sender (gauge type) from another Toyota car that can fit on the 2jz?crontab said:Speaking of gauges, has anyone ever hacked the guages on the stock display? Like the mpg one or battery V one to show something else like boost pressure?
Really? I could have sworn that I saw on the service manual that those small gauges were able to detach from the MPH piece. Guess I'll check it again. So when you opened up the instrument panel to change the lights, you saw that all the gauges were just one piece? Well if that was the case, I wouldn't do it because I don't like to read in KPH hehe...Wxman said:You would have to replace the entire MPH piece on the console. If you did that, you would have to use the center piece from the JDM version and wire it up to make the new gauges work.
-crontab -l
stick said:I know a boost guage is always one, but what are the other two usually and why?
stick
You think you'll run 80 psi anytime soon?IS300GTE said:haven't had the time yet, i thought about it as soon as i got the car, i even did a pretty good photoshop about a year ago of how it would look and put it up on tbko's site, but haven't had the time to actually figure out the circuit
IS300GTE said:i have boost pressure, egt and fuel pressure from defi, along with the unit that records peak and hold and has a 40 second playback
-gte
stick
I would have to agree to that. If I go turbo again with this car then these would be my first 3 gauges as well.IS300GTE said:i have boost pressure, egt and fuel pressure
GTE, I am not doubting your knowledge, but I was asking for examples of why they are needed/used over other guages :wink:IS300GTE said:there is numerous situations why these gauges might be needed or used
stick said:IS300GTE said:i have boost pressure, egt and fuel pressure from defi, along with the unit that records peak and hold and has a 40 second playback
-gte
stick
What is the purpose of knowing you EGT and fuel pressure--to make sure everything is running ok?
Way to write your post inside the quote tag. :crazy:HyperMKIV said:stick said:egt is so you can basiaclly tell if you're running lean. fuel pressure is so you can tell if you're GOING to run too lean or rich...um...sorta...IS300GTE said:i have boost pressure, egt and fuel pressure from defi, along with the unit that records peak and hold and has a 40 second playback
-gte
stick
stick said:GTE, I am not doubting your knowledge, but I was asking for examples of why they are needed/used over other guages :wink:IS300GTE said:there is numerous situations why these gauges might be needed or used
