1 - 20 of 24 Posts
Speaking of gauges, has anyone ever hacked the guages on the stock display? Like the mpg one or battery V one to show something else like boost pressure?
-crontab -l
<crontab>
I have had this exact same thought. I mean, the MPG gage is about useless. I have not read or heard about anyone who has done it...
Podiatrist
I think it'd be pretty difficult.
It's not boost pressure, but I'm sure you can swap out the MPG gauge with the Oil pressure gauge in the Altezza. But making it work is another problem. The oil pressure sensor on the IS just provides a signal for the warning light, so it won't do any good hooking it up to the gauge. Maybe there's a oil pressure sender (gauge type) from another Toyota car that can fit on the 2jz?
i think SophieSleeps can do it :D
he's got way too much time w/ his hands.
seeing what he's done to his mice, table, boxes, etc. :lol:
great works, btw.
You would have to replace the entire MPH piece on the console. If you did that, you would have to use the center piece from the JDM version and wire it up to make the new gauges work.
Really? I could have sworn that I saw on the service manual that those small gauges were able to detach from the MPH piece. Guess I'll check it again. So when you opened up the instrument panel to change the lights, you saw that all the gauges were just one piece? Well if that was the case, I wouldn't do it because I don't like to read in KPH hehe...
haven't had the time yet, i thought about it as soon as i got the car, i even did a pretty good photoshop about a year ago of how it would look and put it up on tbko's site, but haven't had the time to actually figure out the circuit
-gte
-crontab -l
i have boost pressure, egt and fuel pressure from defi, along with the unit that records peak and hold and has a 40 second playback
-gte
stick said:
I know a boost guage is always one, but what are the other two usually and why?
stick
You think you'll run 80 psi anytime soon? :D
Discussion Starter #16
-gte
stick
What is the purpose of knowing you EGT and fuel pressure--to make sure everything is running ok?
there is numerous situations why these gauges might be needed or used
Am I Hype-R???
stick said:
-gte
stick
egt is so you can basiaclly tell if you're running lean. fuel pressure is so you can tell if you're GOING to run too lean or rich...um...sorta... :p
1 - 20 of 24 Posts
