1 - 20 of 26 Posts
I pick up my IS today and I was wondering what blank CD-R's do you use for your burned CD's. I heard some brands are better than others, is this true?
I'm interested too. Right now I use some generic ones from Office Max called Prime Peripherals. I had to slow my burns down from 12x to 8x to avoid skipping in the IS cd player.
So those PNY's don't skip or anything and the IS stereo head unit can read all the .wav files correctly?
If so then best buy here I come.
Any other good brands out there other PNY have you used?
Thanks...
I've been using a 50 pack I got for free from Office Depot. Burn from 8x - 12x and haven't had a problem. They were $30 with an instant $10 rebate and a $20 mail-in rebate....hence free! Keep your eyes open they do it every now and again.
bulk 100 cd's, no cover or logo's of any sort.
i burn @ 16x, no problemo......
BUT, if i scratch the top part, i peel off the cd's reading part.(im screwed in that case)
everything works on IS' CD, IMO...
Any major brand works great, just don't buy the cheap no-names you find at the computer shows. Also, don't put labels on them, the manufactures have found that the heat in the cd players will cause the lable to peel up and jam. - no warranty coverage.
by the way, sticking something on the surface of the CD is just dumb.. you are supposed to write it on.. label and stuff will make the CD spin unevenly causing it to skip or not even read.. unless the weight of the sticker is evenly distributed on the surface of the CD.. but then problem LVmotorsports have pointed out could occur..
so bottom line,
buy brand name CD-Rs for best results and don't stick anything on it!!
then the car stereo will like it
Precisely why I use inkjet printable surface blanks. Then again, most people don't have CD printers.
If you write on them is is much easier (lazy) also. Office Depot is the best place I've found so far for CDs. They always have some kind of sale. The only problem with writing on them is you don't know what you have on the CD. BUT if you are like me you have it on your computer anyway
I've had no problems with Maxell w/labels in my changer. It also plays MP3 files that I have downloaded from Kazaa.com with no problems. The only thing I've noticed with the MP3's is that they don't have the same sound quality as CD files. They are too bright and tinny with the dome tweeters. I usually have to turn the treble down on the deck to compensate.
Taiyu Yuden. Awsome especially for audio cd's. Been using them since I switched from your mainstream brands ie Verbatim, Maxell, Sony, etc. No problems at all.
1 - 20 of 26 Posts
