1 - 10 of 10 Posts
ok. I ordered so rims and the company is also sending me something called a "valve stem" and "spacers". I dont know what these are nor do I know whether to put them on. LMK
I'm getting them tomorrow. :bigSmile:
It's 5 o'clock somewhere.
The valve stem is how you fill your tire with air. The mde for your car according to the rim offset. For instance a 5mm spacer would make a +50 offset wheel appear as a +45 offset....because it moves the wheel outward. A spacer is usually used to clear the caliper. Hope this helps.
P.s. Did they send you hub centric rings too?
Valve stems are mounted on the rim so u can put air in ur tire and spacers r 2 increase the offset.
So they don't already come with aired up tires?! Aww man that would suck if they don't. :pissed:
....details please.
Discussion Starter #7
oh sorry...so both of those parts will come already on the tire and all i do is put the tire on?
Discussion Starter #9
300iss said:
The spacer wont come mounted on the wheel. Just slide it on before the wheel though, and then throw the wheel and and your good to go.
thanks +rep
1 - 10 of 10 Posts
