What are the advantages of a supercharger?
<b>LAG</b><BR>
This is perhaps the biggest advantage that the supercharger enjoys over the tubo. A Supercharger is connected directly to the crank, so there is no "lag". Superchargers are able to produce boost at a very low rpm, especially screw-type and roots type blowers.<P>
<b>Back Pressure</b><BR>
Because the supercharger eliminates the need to deal with the exhaust gas interruption created by inserting a turbocharger turbine into the exhaust flow, the supercharger creates no additional exhaust backpressure.<P>
<b>Ease of Installation</b><BR>
Superchargers are substantially easier to install than a turbos because they have far fewer components and simpler devices. Turbos are complex and require manifold and exhaust modifications, intercoolers, extra oil lines, etc. - which is not needed with most superchargers. A novice home mechanic can easily install most supercharger systems, while a turbo installation should be left to a turbo expert.
<b>LAG</b><BR>
