How long are you giving it before the car settles and you notice one side is lower then the other? is the lower side the drivers side?whenever both my rear coilovers are adjusted to the same ride hight one side it lower than the other. i have to adjust one side higher than the other to make the car level and have the same wheel gap. is this normal?
i usually drive it around it down the street for a few minutes and come back and then check the wheel gap. the lower side is the passenger side. yes i am doing it on a flat surface.How long are you giving it before the car settles and you notice one side is lower then the other? is the lower side the drivers side?
When you adjust the ride height are you doing it on a flat surface also?
wheel gap tells you nothing. unless you have leveled the floor your car is sitting on any tilt can throw off the gap. doing your adjustment when your fuel tank is full or empty will change your setup. having crap in your trunk will change your setup. putting a driver in the seat will change your setup.so is it best to put it at the same wheel gap or have both sides the same adjusted hight? the difference between the left and right are pretty dramatic, but its at the same wheel gap.
probably not. when my c/o's were set at the same height they made the car tilt a little. i think its normal.so you dont think theres something wrong with my coilovers?
