1 - 8 of 8 Posts
I have a 2006 IS250 RWD automatic. Lately over the past few months my wife has been complaining about a mildew smell inside her car and today we found that the carpet under the rear floor mats is soaking wet. :suspiciou
After doing a little digging around back there we found these little plastic pieces mounted underneath the two front seats and it seems like the water is coming from them because they are soaking wet inside them and the carpet around them is really saturated. I'm assuming that they are part of the AC but I don't understand why water would be coming from them.
I've attached a picture to show what I'm trying to describe and hopefully someone can tell me why it's happening and what I could to to fix the problem.
Thank You in Advance for any information you can provide. :)
Super Moderator
This is a known issue that Lexus is aware of and is actually one of the TSB's, a free fix only while under the manufacturers warranty(4yr/50k miles, whichever comes first). Unfortunately unless you have an extended warranty, you'll have to pay out of pocket.
What happens is there's an issue with the condensate drain, so it runs down the vents to the lowest point. I found a thread from our neighbors that goes into detail.(see mainly page 2)
HELP! My IS 250 has sprung a leak!?!?!? - Club Lexus Forums
Thank You jason...... I did buy the extended warranty but it ended in 12/11, just my luck.:(
I did find a TSB on how to repair the problem which doesn't seem too hard.
I do have a question for you about the TSB if you have a chance to read it. On page 8, step #11, figure 13, it tells you to remove the drain plug and look for blockage and clear the blockage, but it doesn't tell you to put the drain plug back in. Am I supposed to leave it out?:confused:
I've attached the TSB I found if you have a chance to look at it I appreciate it, but no hurry, we've been dealing with this for a few months now.:)
Super Moderator
You're welcome and glad you found the TSB and especially that you are still covered. This is something i would definitely let Lexus do of it is free to you. Between reading the threads and TSB, it seems the drain plug is to be removed and NOT replaced. There is foam behind it that shouldn't be removed or disturbed. I haven't seen anything that suggests otherwise.
Thanks for the help and actually I'm not still covered under the warranty. It ended in 12/2011.....
I was able to see where it is and saw the buildup of slime around the drain opening and with a stiff piece of wire I was able to break some of it loose and some water did come flowing out of it but until I get the things out of the way I won't be able to remove it, I could never reach it by hand otherwise.
At least I know what it is and that I can fix it myself.
Thanks again. ;)
Probably a door seal or a sunroof drain. There are two drains at the rear of the sunroof that go down through the C pillar - and probably come out somewhere ahead of the rear wheel opening (dunno since I have a vert - but that's usual BMW practice..) If these plug up - water will end up in the rear. Also - if the door drains plug up - and the inner door seal on that side isn't firmly adhered to the door - you could end up with water. I'd guess there is also a possibility that the rear side window might leak.
I drove my Lexus IS 250 2010 car up on ramps, parking brake on, all wheels chocked. Crawl under from front, on your back head about the middle of the vehicle feet out front. Put KY jell on right hand from knuckles to wrist (not fingers) and slide it up between on right side of tranny right at the linkage (very tight fit until your hand is above the tranny). The plug is under the middle of the tranny towards the front of the car, almost as far as you can reach. There is a soft rubbery nipple that sticks down from the middle. I used a small 4" long multi use pliers that I fed to my right hand from my left hand. I slid my left hand in (with the pliers) from where the driveshaft meets the rear of the tranny. Your hand goes up above the tranny and toward the front of the vehicle until I could transfer the pliers to my right hand. Use the pliers in your right hand to grab the nipple of the plug, hold tight and pull down. I guided the tip of the pliers with my left hand. It is difficult to get your left arm in far enough to just feel the nipple. The part itself is 2" diameter but only about 5/8" diameter of the middle protrudes through the floor and the nipple is in the middle of this and has a slot about 1/2" long by 1/16" wide, this is what clogs up with dirt and won't drain. Once the 2" diameter plug is removed, the hole in the floor is only 5/8" diameter, you can't stick your finger up into the hole. Do not replace it, this size of hole should not clog up now. I am 5' 10" tall weighing 190 lbs, my left forearm is 11.5" circumference, my right hand is 2 3/8" thick from the back of my hand to the thick fleshy part of the thumb on the palm side, you need to wiggle the right hand around to get it up beside the linkage.
1 - 8 of 8 Posts
