nice good to knowI'm at 115,000 miles and am using the original water pump without problems.
TeCKis300... it's as simple as this. When it starts to go... you change it. Why replace a perfectly functioning part? The timing belt is different... it is critical... and if it goes... it catastrophic. If the water pump starts to leak or make a noise... well then you just change it.And I take it that all of you guys don't have insurance either...
This is NOT the place to save money IMO.
The only reason people recommend to change the waterpump at the same time as the timing belt is because you need to remove the same parts to access those items. It's not because the waterpump is going to "expire" at the same mileage as when you change the timing belt.impressive.. but i would still change it when suggested just to be on safe side
Actually...it is!TeCKis300... it's as simple as this. When it starts to go... you change it. Why replace a perfectly functioning part? The timing belt is different... it is critical... and if it goes... it catastrophic. If the water pump starts to leak or make a noise... well then you just change it.
And the reason they recommend changing it is to save money. If you take your car to a shop you're gonna be charged several hundred bucks in labor to do a timing belt. If you don't replace the water pump then you'll have to spend another several hundred to replace that before the maintenance interval of anything you just replaced is up.The only reason people recommend to change the waterpump at the same time as the timing belt is because you need to remove the same parts to access those items. It's not because the waterpump is going to "expire" at the same mileage as when you change the timing belt.
Playing Devil's advocate here:Actually...it is!
"When it starts to go"...is going to be that one time when you are not paying attention to the temp gauge until it's too late. Whether you are running hard or cruising in the desert and daydreaming....and don't notice your temp gauge until steam is coming out of your hood. One overheating event is enough to warp the head and blow a headgasket.
It's all about preventative maintenance, especially on a relatively cheap waterpump.
That is why you stick with Toyota/Lexus OEM components.... ESPECIALLY if you are doing it yourself.... I'm only at 62k... so this is a bit off for me...., but I'd recommend to service in the following order... coolant flush, timing belt and waterpump service. Flushing BEFORE the new pump removes all the scale and crud from inside before you put a nice new pump on. Nice new Toyota coolant, along with a nice new pump and a nice freshly cleaned cooling system will lead to another 90k of no worries.........Playing Devil's advocate here:
Why change a perfectly good working part with a new, potentially defective, part? Who's to say the new part won't "start to go" a week after you put it in?
That goes against regular maintence.... you want to prevent things from breaking, because generally when one item fails, other items get affected, costing you a lot more.TeCKis300... it's as simple as this. When it starts to go... you change it. Why replace a perfectly functioning part? The timing belt is different... it is critical... and if it goes... it catastrophic. If the water pump starts to leak or make a noise... well then you just change it.
What if you just had to drive across country tomorrow. Do you want a car you can depend on or do you want a car that you will have to cross your fingers that it wont need a water pump replacement?
