Ok, well- here goes:
I have located an r154 tranny that I'm picking up, and I have a 1JZ bell housing on the way from Japan. I still need to get an mk3 master cylinder and fork assembly, clutch, flywheel, and pressure plate, measure for a driveshaft, tranny mount, shifter relocation, etc.
SO, in the meantime, I'm swapping in a w58 from a mk4 N/A supra. The gears are a LITTLE longer with the stock rear end, and while in THEORY it is the same tranny as our w55 but with different gearing, in PRACTICE there are MANY sc300 and mk4 NA-T guys running around with over 400-500rwhp on stock trannies. True, some have blown their trannies, but many have not. Pretty much everyone is blowing their w55s, with some exceptions.
The w58 will be in this sunday. I can reuse my rps pressure plate and clutch, driveshaft, short shifter and linkage, etc. the tranny casing is the EXACT SAME as the w55. PLUS they are abundant and cheap, seeing as they were in the mk3 n/a supra from 87-92, the n/a mk4 supra from 93-98, and the sc300 from 92-97. To solve the gearing problem I may put in a 4.1 rear end LSD. We'll see how bad the longer gearing is.
This is just a temporary swap to tide me over until I can get my r154 ready to install. Finding the bell housing was the hardest part, but it's en route. I got it used from japan for $225 +shipping. Another guy I found can get it new from Japan for $500 shipped anywhere in the continental US. Both are great prices. Contact me if you need help locating one for a swap.
To all who have helped me and sent me best wishes, thank you. I have reasearched up the ASS, and found some GREAT online websites, including:
www.drivetrain.com,
www.reanimotion.com/ToyMods/techdata.htm, just to mention a couple.
www.Supraforums.com also has a lot of info- you want to look at the 1JZ (JDM engine) swap for the mk3, and can find lots of info on how to make the r154 tranny mate up to the JZ bolt pattern.
Hope this helps out some people!
Car should be back on the road this weekend!
-Chris[/url]
www.drivetrain.com,
-Chris[/url]
