Soooooo...shooting in the dark here BUT, does anyone happen to have this info. Trying to tune vvti on my aristo motor with the V2. If someone has a cal or screenshot of the vvc map and the vvc settings to configure its functionality in the V2 this would be AWESOME!
Dunno if this reflects the "stock" Toyota calibration, but it was shared with me as a means to get going. I've NOT run an engine with this calibration, so use at your own risk... FWIW, it looks somewhat reasonable to me, with more advance (creating more torque) at higher desired loads and lower rpm - trailing off as engine speed increases, where you wouldn't want the advance anymore.
Good luck!
Thanks much for that! Would you happen to know the VVC setup info in the V2 (the VVC1 options tab info in V2) ?
