1 - 2 of 2 Posts
I have a 2005 IS 300 and when i went to start it the other day the VSC light, TRAC Off light, and check engine light all came and stayed on, the car started fine but as i pushed down on the pedal the engine did not rev at all, it wasent until the gas pedal was pushed all the way down to the floor the engine just redlined didnt start out slow or anything. anyone know what this might be?... thanks!
I would have the check engine code checked. That should give you a decent indication of the problem. You can use an odb2 scanner or various auto parts stores that will do it for free.
1 - 2 of 2 Posts
