1 - 2 of 2 Posts
Alright, I purchased the pioneer nav, but it didn't come with the Mic.
I should be getting it according to the guy I bought it from, but instead of using the wired mic.
Would a Bluetooth enabled mic work ?
Meaning attach a bluetooth adapter into the 2.5mm plug and use a blue tooth enabled headset ?
How possible is it to run some type of adapter to keep the Bluetooth adapter charge while the car is running ?
With some work, it would be possible to get the bluetooth mic, as well as the charger work. Soldering will be required.
You can get stabilized voltage for the charger from readily available chips for 5V or 9V using car power. Anything different will require working around it.
Personally, I don't see a reason to go thorugh all that. Just put a wired microhpone somewhere close to you.
I've outsourced a good place for microphones for my project. Unfortunately, they are only compatible with a specific system input (my system has it).
1 - 2 of 2 Posts
