1 - 20 of 57 Posts
Voice Activated Navi Command List:
Here are some, if not all of the voice activated commands, I believe. Bartkat if you have another document that lists all the commands can you either replace this post or add to it? Personally I find it helpful to carry a cheat sheet in the car, instead of having to seek out "help" to review the list.
Anyway, hope this helps:
NAVI Commands
Command Alternate Commands with same function
Current position Current Location
Map
Cancel
Zoom In
Zoom Out
Right Map Zoom In
Right Map Zoom Out
North Up Change to north up
Heading Up Change to heading up
Map direction Change to map direction
Right map north up
Right map heading up
Right map direction
Dual map Change to dual map
Single map Change to single map
Mark this point Mark
Home Go Home
Repeat Guidance Repeat voice, Repeat
Louder
Softer
Arrow guidance Arrow guide, Change to arrow guidance, Change to arrow guide
Turn list guidance Turn list guide, Change to turn list guidance, Change to turn list guide
Entire Route map Entire route, route overview
Delete next destination Cancel next destination
Delete final destination Cancel final destination
Delete all destinations Cancel all destinations
Suspend guidance Stop guidance
Resume guidance Start guidance
Compass mode Change to compass mode
Lane guidance Change to lane guidance, Guidance screen on freeway
AUDIO Commands
Radio
AM AM Radio
FM FM Radio
FM1
FM2
CD
DVD
CD Changer
DVD Changer
Cassette
Tape
Audio Audio on, Audio off
Seek up
Seek down
Type up
Type down
Fast forward
Rewind
Reverse Program
Next track
Previous track
Skip backward
Play
Track up Next track
Track down Previous track
Disc up Next disc
Disc down Previous disc
Climate Commands
Automatic Air Conditioning Automatic Air Conditioning On, Automatic Air Conditioning Off
Raise Temperature Warmer
Lower Temperature Cooler
65 Degrees Temperature 65 Degrees
82 Degrees Temperature 82 Degrees
83 Degrees Temperature 83 Degrees
84 Degrees Temperature 84 Degrees
85 Degrees Temperature 85 Degrees
Help Commands
Help Command help, Command list
Home
Quick Access #1
Quick Access #2
Quick Access #3
Quick Access #4
Quick Access #5
Quick Access #6
Previous Start Point
Previous Destination
Nearest + POI Category
Show List
Add
Change State
Change City
Change Street
Change House Number
Enter Destination
Add to Destination
Replace Destination
Thanks for posting these. The last couple times I tried the voice activation, it kept turning the audio off. LOL, I figured it couldn't understand my WV accent. I'll give these a shot and see if I have better luck.
+REP!
oh god, i'm never going to memorize all of these commands.. i've been using "dial by number" and "home" a lot.
+REP!
LOL! Remember to wait for the beep, after pushing the voice activation button. Also, if you want to take a look at all the commands on the screen just say "help" after hitting that same button--from that point you can scroll down to see them all.
Neat lil Nav trick
Well, having used the previous nav, some of you may already know this and it may be as obvious as the sky is blue. However, when you hit the Map button while driving it lists the street number and town you are, It has helped me a number of times already and is very accuarte...oh well, just thought id share
Geezer
So if you call someone for directions you can tell them exactly where you are? hahaahah
The weird thing about the navigation is they cant find certain house numbers, for example, mine. The closest house number it locates its 20 numbers down.
I think it's the way the database is structured. Both the NAV in the Lexus and online services like Mapquest locate my house 1/2 block down the street.
Do any of you have the list of NAV voice commands, I keep messing around and now I have so much crap showing on the screen, ie. restaurants, golf courses and gas stations, but I cant clear it?
Thank you for the help.
jhoo...you can clear all that, i think its under menu or something, just turn off the POI. As for the accuarcy, even on the previous nav it was way off...however, this time if you push the map button the street numbers in the areas i have pushed it were incredibly accurate
Discussion Starter #14
I found that cool, I also like the feature that moves the icon fast forward to your destination.. ala preview mode. Still learning more and more about this darn system, it's full of surprises! :)
POI Retuarant = "I'm Hungry!" ... no kidding it really works... :cool:
just press VC button on wheel and say HELP... it will give you commands you can use
regards.
thanks for voice list. Where did you find it? I've been trying to find the ac commands but I don't see them in the manuel or on the help screen.
Discussion Starter #20
I went through and tried them out then posted! ;) No it was posted online somewhere a while back. Haven't found anything for AC yet either, but I'll keep looking!
1 - 20 of 57 Posts
