very simple question how man quarts of oil do i need
1057 Views 24 Replies 15 Participants Last post by  MTRAPPO
i am in a rush please give me a simple answer i'm about to go buy oil for my first oil change thanx
1 - 20 of 25 Posts
5.7 w/ filter change
5.4 w/o filter change
do not fill with all 6 quarts!
Buy one 5 quart container and a 1 quart container, but just use .7 of the quart after you put in the 5.
yep^ :wink:
what would happen if you put all 6 quarts in?
called high blood pressure and your car could have an "anuerysm", sheit could be deadly my friend.
ever see a fat man's face turn purple, and then jus passes out, think of your car that way :lol:
NICE analogy!!! :lol: :crazy: :eek: :D
DL said:
6 qts
And you're welcome.
RTFM before giving out advice like that! if you don't know shit about the quantity of oil to pour in, don't just give a round-about number... :roll:
no prob :p
kraze8 said:
DL said:
6 qts
And you're welcome.
RTFM before giving out advice like that! if you don't know sh*t about the quantity of oil to pour in, don't just give a round-about number... :roll:
If you pull the oil filter you will need all 6quarts. I use a full 6qts when changing my oil and it lines up after getting warm right up to the line, never exceeds the line. I guess some people just keep the same filter for the life of the car and use only 5.7qts. And if you don't change your own oil you should not being saying anything yourself.
kraze8 said:
DL said:
6 qts
And you're welcome.
you cant buy 5.7 quarts bud. He gave the correct answer.
DL said:
kraze8 said:
DL said:
6 qts
And you're welcome.
Yep. The engine will just throw out the excess and it will end up at the full line. That's waste, and not environmentally sound.
Use the V8 Toyota Filter and you can use the full 6 quarts.
are you serious? really?
:D
DL said:
kraze8 said:
DL said:
6 qts
And you're welcome.
incorrect; manual states 5.7 WITH filter change; 5.4 w/o filter change.
Cleo said:
DL said:
kraze8 said:
DL said:
6 qts
And you're welcome.
change the oil yourself and see, I do my own oil change so maybe my car has some gremlin. Most shops will use all the 6qts also after chaning the oil and it lines up right up to the max line and does not go over.
DL said:
kraze8 said:
DL said:
6 qts
And you're welcome.
:roll: :roll:
how do you know I don't change my own oil?? don't assume when you don't know :shame:
if you had read the manual... it says to fill with 5.7 WITH a new oil filter change and 5.4 WITHOUT. if you pour all 6 qts in there, and wait until it all drips down into the oil pan before you pull the dipstick out, you will see that it will exceed the max line. you shouldn't check the dipstick right after the last bottle empties into the engine.
HoustonLex: you're right, you can't buy 5.7 qts of oil. But you're not suppose to pour it all in either. :crazy:
If you have a turbo charged IS300 which DL has then I think 6 quarts is right, since the car use's more oil from turbo and return line and burns a little bit faster, someone with knowledge pleez chime in.
I did put all 6 quarts in and it was fine.
1 - 20 of 25 Posts
