1 - 20 of 22 Posts
Hi Guys,
Used car I mentioned (in my previous thread) was PERFECT except
the previous owner smoked (a lot) inside the car. Dealers are saying they can try and clean it up (with some spl kind of cleaning)
I & my wife are non-smokers and don't like the smell.
Do you guys think there is chance to get rid of it with some kind of cleaning?
Please feel free to give your opinions
Thanks
K
P.S: So close to be proud IS300 owners :(
Dealers get smoker's cars in lots of times and they clean them up. Motels also manage to get rid of smoke odoer in rooms. They should be able to do that for you. I know the dealers will usually knock some off of the trade in value to cover the cost of deodorizing.
Personally, I would try to stay away from a "Smoker's" car. I doubt you can get all of the smell to vanish.
Fabreeze works for like 15 minutes... i wouldnt rely on that...
if you crap in the back seat, you'll hardly notice the smoke smell... :wink:
theres some kind of lysol spray with a pleasant aroma (fresh scent or sumthin) kills odors and dries fast. its cheap 1-2 cans should do it
can let you car bake in the sun and hope the odors "steam" out. wild idea though
hope that helps
btw i always smoke OUTSIDE my car, remember one time my homeboys wanted to "chamber" in my car and i was like F..k dat!! still got smoke the goods out of my car :)
you will never be able to remove the smell. after you use all those cleaning products of corse the car will smell better, but they come back. smoke is a very fine particle, and it finds its way into every little nock-and-cranny........ your even more screwed if the driver left the air on re-circulate. now you have all those particles in the air vents. if the smell bothers you then don't buy it. you'll thank me in the long run. it will end up giving you headaches too.
good luck
If you have an air cleaner, use it inside your car every night.
I have the honeywell air cleaner and I use it on my car every weekend.
In case you dont have one, dont buy the small ones(plug-ins) because they are not as effective as the big ones for home use.
Wouldn't it be easier not to buy a car that you have to use an air cleaner every weekend? Maybe, not smoke in the car if that is why you use the air cleaner?
It would definitely be better to buy a car that was owned by a non-smoker. I was assuming that he was fixated with the car (despite of the smoke odor).
Also, I dont smoke. I use the air cleaner just to keep a fresh scent inside the car.
Driving the car will do the trick. :wink: No air cleaner is needed.
I put 56K miles on my previous IS and did not have any smell in it.
1 - 20 of 22 Posts
