It's not hard to add HID's to the JDM lights. You can get an HID plug and play kit. You plug one end of the aftermarket ballast into your stock clip and the other into the HID bulb that will come in the kit. I think the JDM lights are 9006 for the low beams. So, all you would need would be a 9006 HID kit, which AAC sells. Get a set of JDM lights, then slam everything in. You'll be better off because you'll get what you want and the JDM lights will have never been opened. Not to say AAC doesn't do a great job (I've owned two sets of lights from them and couldn't be happier) but you can always run into problems. I hope that helps.
