1 - 12 of 12 Posts
· Registered
i love the way stock sounds.but would it be alot better just to replace every speaker to a more top of the line speakers? lets say im just keepin the stock head unit?...and also...how would i get alot more bass without compromising trunk space, doing custom work, and just using the setting available?..i mean..if i upgrade the built in sub in the stock system..would i get alot of good bass?..please help..
julian
· Registered
your system wont sound so great with just aftermarket speakers... youll AT LEAST need an aftermarket amp also.... and i didnt know the IS300 came with a built-in subwoofer.... the IS300 only has 6 speakers to my knowledge... 2 tweeters, 2 6.5" speakers, and 2 coaxial 6x9" speakers... thats six, but you could stretch it and call it 8 speakers ( 2 coaxials ) but theres still NO subwoofer in that mix...
anyway, if you want to upgrade your system, youre gunna need to do the whole thing over...
· Registered
Spend about $600 on Dynaudio and leave your stock system in. It will make a huge difference and your resale won't suffer a bit. It's unbelievable what these speakers can do with a stock setup. But, a sub with its own amp would help quite a bit to round everything out.
· Useless
Fact is that the IS actually has 8 speakers. The mids and seperate tweeter in each front door, and the so called 6X9 coaxials are actually a 6X9 WOOFER with a seperate mid/high mounted with in it. The factory amp sends the lower frequency's to the 6X9 and the upper range to the seperate speaker back there. In terms you could say that each speaker is just one speaker, but it actually is driven by its own amplifier channel. This is why so many people say that when they changed the speakers it sounded like ****. If you get a stealth component 6X9 like Lanzar(Not endorsing, I just know that these are this way) they have seperate inputs on the speaker for the low freqs and the hi freqs. This will allow you to change to an aftermarket speaker and get more than just the high frequency's, or just the low's. Also, please note that the woofer is running in the factory system at 2 Ohms and the mids/highs are running at 4 Ohms. That means that the woofer portion is receiveing at least 50% more power than the highs. Make sure that if you upgrade you replace the speakers with the same impedance. If you want to increase bass without losing the trunk here is a simple idea, but its not the cheapest.
Remove the factory 6X9's, purchase a pair of USD audio Pro 6's. These are a 6" subwoofers(Yes an actual sub) that handle good amounts of power. These will set you back about 200 a piece. They are worth it as these 6" speakers can produce the same 40HZ SPL as 2-10" subs mounted in a ported enclosure. Also purchase you favorite brands 3.5" speaker. Make a mounting block out of wood that will hold both the 6 and 3.5 speakers and mount to rear deck using factory hardware. Use the factory amp's high rear out put and connect to the 3.5's. Use a linelevel converter and hook to the rear low freq amp outputs. Install a good amp that can deliver at least 300 watts mono and connect to the 6" speakers. If properly done the amp can be mounted under the rear deck as it will not take hardly any valuable trunk space. Using this combo is the equivalent of installing two 10's. You will have much better low-end extension, and more basssssss! This is only 1 or I'm sure 1000's of methods, but I just did this combo on a customers car and it absolutely blew his mind.
· Registered
in the expedition of mine,i have 3 12's with 1500 watts pumping to it,with just the stock speakers ,but a pioneer head unit,an its dynomatted
trust me,you need aftermarket speakers or atleast another amp to run to the stock speakers, because i have so much bass in mine i have to turn it up pretty much half way just to get enough music to equal out the bass,hope that helps
· Useless
s0yb0mb
I used an aftermarket amp as the factory one is in no way powerful enough to run subs. Pick any good named brand with at least 150 watts will be fine.
1 - 12 of 12 Posts
